Trailer Wiring Holders
chim
L4240HSTC with FEL, Ford 1210
Jan 19, 2013
2,123
1,244
Near Lancaster, PA, USA
I'm almost finished with a refurb on a trailer I built back in '91. While it was stripped down, I harvested a bunch of links from a light chain. These are welded all along the inside of the trailer frame. Wires are run through them and ty-wrapped . With the rounded surfaces, abrasion shouldn't be a problem.
Roadworthy
L2501 HST
Aug 17, 2019
1,649
526
Benton City, WA
That's a clever idea - it would have never occurred to me. I just use half inch EMT bent to shape to protect trailer wiring.
4,914
I've used 1/2" black 'poly' pipe for decades, 100% front to back, both sides.
Also solder the connections INSIDE the housings.
5,066
I tried to.... "solder the connections INSIDE the housings"..... once.
Soldering iron was so tiny/weak it just would not melt the solder "inside the housings" . :ROFLMAO:
Mark_BX25D
Bx25D
Jul 19, 2020
1,756
1,278
That's pretty clean. (y)
I think you'll find the white tie wraps will give you a year or two, maybe 3 at the most before they get so brittle they'll break if you smile at them. The black ones hold up much better. They aren't degraded by UV nearly as badly as the white ones.
3,316
UV shouldn’t be an issue beneath a trailer. I use EMT or other conduit…last job was flexible EMT.
C15TA
170 Allis Chalmers , 580E Case & BX25D
Oct 1, 2015
Castleton ON
It is. Reflections! Not as bad as in full direct sunlight, of course, but it still matters. BTDT.
The Toronto Transit Commission just recently scrapped all the white tie wraps and changed to black. They had continual issues with the white on their bus fleet.
