EZ - Peazy Remotes
5,685
It seems like people post almost daily looking for help adding rear remotes to their tractor. Everyone seems to want a "kit" so here is my contribution to the cause. This is fitted and tested on an L3901 but should work on most "newer" open station L series machines with loader. It comes with a 1, 2, or 3 spool valve, valve mounting bracket, and all fittings and the two custom fit hoses needed to hook it into your loader circuit. Thats right - you only need 2 additional hoses and you should be able to install this in roughly 30 minutes. You don't have to know jack about hydraulics - just how to connect up 4 hoses.
Reactions: 6 users
7,070
Dan - great choice for a thread.
I’ve seen you answering the same/similar question many times over.
Your patience is admirable in answering each and every one.
Probably should be a “Sticky,” but many folks miss those.
5,685
Sorry to hear that, Dan.
Thank you for your concern.
To date my health has been very good but I got blind sided by a respiratory attack last week and spent 7 days in the hospital. I am home and slowly getting better but still tethered to an O2 generator and have some rehab to do going forward. If I do my part and get a little luck the shop may reopen somewhere down the line.
7,070
@TheOldHokie - -
Dan - - so sorry to hear of your setback.
I noted hip replacement has been a challenge, and now this....
Certainly extend my best wishes for a speedy recovery.
