I have a L235 that I'd like to add aux. hydraulics to lift a dump wagon or maybe a hydraulic top link for the 3 point. I've had several Kubota tractors over the years (B7100, L2900) and both of those came with a block with threaded ports, blocked by bolts. All you had to do to add aux. was remove the bolts, turn a valve, and install the right quick connects. The manual for the L235 indicates that yes, you can add aux. hydraulics, but it appears that you have to find a block to attach to the hydraulic flange outlet. I found an old post with a picture of what I need. Does anyone have that part number or a lead on where to find one? I'll try to post a picture of the part I'm looking for. thanks
