Looking for lower link arms about 26" in length that would fit a Kubota L35. Also looking for the fixed drawbar.
The parts you are looking for (for L35), are going to be VERY difficult to find as used parts.Looking for lower link arms about 26" in length that would fit a Kubota L35. Also looking for the fixed drawbar.
Currently I have lower link arms from a Ford tractor which are too long and no holes for the stabilizer chains. A pain to change implements since the sway chains use the same pins and have to be removed.The parts you are looking for (for L35), are going to be VERY difficult to find as used parts.
I believe that those pieces may still be available new, but are likely VERY spendy.
Unless you find some good used ones (or the missing stash of misplaced ones ), I think you'll do better to buy the L3961 kit from your dealer. It's around $600 now.Looking for lower link arms about 26" in length that would fit a Kubota L35. Also looking for the fixed drawbar.
Thanks for info on L3961 3 point hitch used on the L35. Have you installed the kit on your L35 yet? I would like to know how it works out.Unless you find some good used ones (or the missing stash of misplaced ones ), I think you'll do better to buy the L3961 kit from your dealer. It's around $600 now.
L35 Hitch Kit 3-point
I have a L35 and I'm looking for the 3-point hitch kit. The dealer says they are about $1800 after they put one together. I've also read that a L39 3-point hitch kit will work and can get them for $500?www.orangetractortalks.com
If you search this forum by 'L3961' and my name, you should find some pictures I posted with dimensions.
I have the 3 pt arms for L3750. Near PhillyLooking for lower link arms about 26" in length that would fit a Kubota L35. Also looking for the fixed drawbar.
Coleman Equipment has the L3961 3pt. hitch kit listed on their website for $594.72...... plus shipping.Looking for lower link arms about 26" in length that would fit a Kubota L35. Also looking for the fixed drawbar.
No, I haven't. I don't think the backhoe has ever been off.Thanks for info on L3961 3 point hitch used on the L35. Have you installed the kit on your L35 yet? I would like to know how it works out.
I tried my L3961 parts. The lower arms I couldn't install to the rear because of interference with the backhoe. But I put them pointing to the front - the eye is the correct size and length for the pin.No, I haven't. I don't think the backhoe has ever been off.
If I can, and remember (CRS setting in), I'll see if the lower arms fit. I think I can do it without removing the hoe. May be Monday.
BTW, you should be able to save shipping if you get it on your dealer's shop order. Worth considering.
Can you take a pic of lower link arms with measurements from ball to ball, Have any idea what you want for them, with shipping to Southern Illinois.I have the 3 pt arms for L3750. Near Philly
