I own a B2150hsd 4wd, 24 hp / 20 hp pto, with only 700 hours on it. Bought it used with only 200 hours 20 years ago and immediately changed the hydro fluid with Napa premium due to now knowing the tractors history. I changed hydro fluid again at 400 hours and 600 hours. Each time with Napa premium and replacing filter and cleaning the screen. And yes, the manual calls for 300 hours for hydro fluid replacement.
The past couple years the tractor seems to go a little slower uphill, nothing steep just a moderate grade, with the brush hog attached. Is it possible that less power is hydro fluid related? I can not say this happened right after changing the hydro fluid 100 hours ago but the tractor does feel different the past year or two. And, a few years ago I noticed the hydro pump, or hydro system in general, seems to be a little bit noisier sometimes in hotter weather when raising the brush hog. Admittedly Kubota calls for a 4 ft on the B2150 and I use a 5 ft brush hog.
I researched and found a person changed from Napa premium to TSC premium brand and claimed the tractor had more power, performed better. This could be placebo related or perhaps new oil just performs better.
Anyway, is it possible changing the fluid from Napa to another brand could change the performance, even slightly? Or, the change in performance is relative to the tractor having more hours on it? I am considering going with Chevron 1000 THF or Delvac. It is not cold here so no reason for a synthetic. The last hydro fluid change was 6 years ago. And not to start an oil war regarding Napa products but per VOA's Napa synthetic motor oils are near the bottom when compared to other brand car oils regarding additives and such. Could not find a Napa Premium hydro fluid VOA so have no idea how it actually compares to others. My guess is Mobil and Chevron hydro fluids are also better products than Napa. Not that Napa is bad, does not work, or does not meet spec. I have used Napa 5w/30 and Napa oil filters more than once in my car.
