L3560 Wheel Weights
3P Kubota
L3560
Apr 25, 2022
Does anyone know if Kubota makes a bolt on wheel weight for the L3560? It seems like it shouldn't be this hard to find but it is turning out so. I am looking for around 500# per side. I checked with Taylor Foundry and they didn't have any at the time.
Thanks
MOOTS
MX6000
Jun 27, 2019
2,202
2,769
Canton, Georgia
Salesman should be able to look them up.
Everything attachments has a bunch.
Lonestarweights has them too, may even be local.
6,933
Thanks
What wheels and tires? Factory weights are available for R1s.
SDT
Apr 15, 2018
3,635
1,359
Thanks
Don't know if Kubota offers rear weights for 3560 with R4s but do know that the maximum number of rear weights for an L6060 is 3 per side. Weights are about 103 Lb's each so you will not approach 500 Lbs per side.
Have your dealer check with North States for weights. They make many weights for manufacturers and sale to dealers. Must have dealer check as North States does not sell directly to consumers.
3P Kubota
L3560
Apr 25, 2022
Dan, I am running 12.4-24 R4 rear tires. I have some 12" round that I was going to use but it is going to be a challenge rigging the brackets up to mount. They are around 500# each. Thanks!
3P Kubota
L3560
Apr 25, 2022
So I contacted my local Kubota guys, very helpful, and long description of what I am needing. The short of it is Kubota PN-L8066, stackable up to 3 but only 60# each. A far cry from the 500# per side I am looking for but there is a part number anyway. Thanks for all the comments and suggestions folks!
ctfjr
L3800HST
Dec 7, 2009
1,982
2,539
central ct
if you fill the tires you should get about 250lbs on each one. That plus the std wheel weights pretty much gets you there.
6,933
Better than nothing. I think those are the same weights used with the R1 (24") wheels on the L01s. The R4s on the standard L are 19.5" and Kubota in their infinite wisdom doesnt have weights for them.....
Servmgr64
Kubota Grand L3010HST, BX2350 various implements
Jan 6, 2016
11
Poweshiek county Ia
My local dealer ordered some aftermarket weights for me last April, they are supposed to be in in the next couple of weeks. I am getting 200# per side, they bolt on & I have R4 tires. Weights & bolt kits were in the $600.00 range.
