Hello all, I am new to OTT.  I have a new RTV520 and would like to add lights, etc.  I discovered several extra connectors on the harness with blue tape, but really need a wiring diagram or schematic.  Any idea where i can find one?  Thank you!
								Thank you for the information, and the quick response GreenvilleJay!I saw/downloaded Kubotabooks.com has an RTV900 WSM ,chapter 8 electrical, has wiring diagram.
It should( ??) be similar, at least wire colours (??) to your unit ??
Might be a start of the adventure !
Jay
Thank you Lugbolt!if they have blue tape on them they're usually accessory connections. Radio, light, etc.
if everything is working and no blowed fuses, then there is no problem.
I attached a PDF of wiring diagram for the RTV 500. Should be very close to same as RTV 520.Hello all, I am new to OTT. I have a new RTV520 and would like to add lights, etc. I discovered several extra connectors on the harness with blue tape, but really need a wiring diagram or schematic. Any idea where i can find one? Thank you!
Thank you kdparker, the design is very similar, but there are differences. I purchased a RTV520 WSM manual and "printed" the electrical drawing page to a PDF document. I attached the file with this message for anyone else looking for a RTV520 electrical drawing.I attached a PDF of wiring diagram for the RTV 500. Should be very close to same as RTV 520.
Thank you for posting the wiring drawing for the RTV520. Were you able to use the extra connectors that you found wrapped in the blue tape? My Dad just purchased a new Kubota RTV520 and we plan on installing a GPS Speedometer on it. I ran across those connectors you spoke of but I was hesitant to mess with them. Thank you for the helpThank you kdparker, the design is very similar, but there are differences. I purchased a RTV520 WSM manual and "printed" the electrical drawing page to a PDF document. I attached the file with this message for anyone else looking for a RTV520 electrical drawing.
