Good morning Dave. Glad to hear you are handling the new technology well, I too sometimes get overly frustrated with how all of this works.
Thank you for replying. the problem started before the replacement pump. I am only replacing the pump because the housing cracked upon my removal recently. The pump was not leaking before and did a great job. Like we have stated previously, my problem seems to be only when I use the controls to bring the loader down. I am not a hydraulic whiz, but I would think that would be the least laborious on the engine. Maybe a valve in the control body is not letting the oil bypass? Not sure how this works, but the pump should not have to work while lowering the loader would it? I have attached pictures of the valve. Maybe replace this?
There was a quick coupler in the pressure line outgoing in the pump, I thought that might be the cause, so I plumbed it out and still had the same issue.
I have purchased a Webster Model 077yc001701-lf to replace the cracked pump. this is the OEM pump that came with the loader. I could not use an alternative as there was not enough room to install it. I am sorry but I do not have a link but as I said, this is the same pump that came with the loader.
I currently have the tractor totally stripped down and going to do some replacements/maintenance while the loader is off. The new pump comes in a couple of weeks and I will start putting it back together again.
I will replace most of the hydraulic hoses on the loader, will replace the hydraulic oil filter and drain and clean the tank for the loader so that I can rule out any of those. The oil was clean when I drained it and I can see oil flow thru the hose taking oil to the pump so I doubt those are the issues. I love these old tractors and enjoy tinkering with them, but am so sorry to ask all of these questions when I do this. I do greatly appreciate your help all of the past years. You have helped me navigate through alot of head scratching. Thank you sir. Mark
