May I ask the reason why you want to replace them ?
Yepper, Glow plug lights on the console for the past season. Tractor now takes for ever to heat up and turn over when starting. Wanted to start with replacing the glow plugs.No! It's not allowed!
Hi Russell,Disconnect battery ground cable
Remove the small nut that is holding the wire onto the glow plugs. The nut may be round with a slot and the wire will be a metal rod.
Use a deep thin wall socket to remove the glow plug.
There are no gasket or seal involved probably but verify that on a illustrated parts list.
Thanks for sharing Thatoneguy! I'm hoping for the same outcome.When i bought my b7200 the old owner said it was hard to get started and i assumed it was a faulty switch or a bad plug.... after tinkering with a test light, i pulled off the aluminum wires connecting the glow plugs together and cleaned the contact points with some fine grit sand paper. Works as it should now and fires much easier than it did before. Just a thought if thats the boat your in. Took me all of 10 minutes.
Mechanically, it's very similar to removing spark plugs in a gas engine. If you've done that job, you'll be in friendly territory right away.Any other direction you can share would very much be appreciated
Thanks Mark - I'll take a closer look at the engine to see if I can locate them.It's very similar to removing spark plugs in a gas engine.
No offense taken. Just a new by here learning as I go!You shouldn't have to remove your engine to take out the glow plugs.
Think "skinny spark plugs" with bolt on wires (not boots) and that's all you really need to know.
Most of us should be able to do this job. If you cannot for some reason, please get someone qualified.
(re: my previous comment in this thread--I'm sorry), but I honestly thought your question was a joke. My apologies.
Thank you for the thoughts. Replaced the glow plugs. No issues. Glow plug console light is now gone.It might be wiser to evaluate the operation/condition of the glow plugs before changing them.
One thing that can be done is to measure and compare resistance of each glow plug. They should be about the same. Not sure but likely around 1 Ohm.
A better check to measure actual ampere flow through each glow plug. But you need an ammeter for this.
A basic first check is to verify you are getting voltage to the glow plugs to begin with. This can be done with a cheap, readily available voltmeter.
Just a couple thoughts…
Sorry. Engine cranks, but won’t fire/start. Which what I am reading, rules out the seloniod and the starter, correct? I checked and it’s getting fuel from the tank to the pump. Battery is fully charged and I just replaced the battery cables and ground down the chassis to get a better connection for the black cable. And as I shared earlier, I replaced the glow plugs because I had a glow plug console light on at all times.Just for clarification, can you further describe the issue you are having, when you say the engine doesnt turn over do you mean it doesnt start but cranks or nothing happens at all...
If the issue is that it doesnt do anything, glow plugs would not be the problem. It possibly would be starter related. I would check wiring to make sure connections are not corroded, a rodent didnt chew through anything, check grounds, etc. If the tractor is stored out doors, humidity and other factors may play a vital role in electrical components. I have jumped a solenoid on an automotive starter to check its function on a car, im sure a tractor isnt much different. Most autopart stores can bench test a starter as well if you pull it out.
Have you confirmed the engine or transmission isnt siezed in anyway?
I just tested the fuel pump and no fuel is coming out if it when I turn my key to light up the glow plugs. Is this correct or shou;d the fuel pump be passing fuel to the fuel injectors when I turn the key to light up the glow plugs?It likely could be an issue with the fuel cutoff device that is part of your tractor. Generally the engine is shut down by cutting off the fuel supply. Sometimes manually, but often on newer tractors electrically.
IF you have a electrical fuel cutoff setup, you could have a failed fuel cutoff solenoid or a power supply issue feeding that solenoid. That is where I would look at this point.
Perhaps someone who knows your specific tractor can offer some detailed help…
"bad diesel in it" ????Oh okay, that clarifies things a little better. If the engine is cranking chances are its fine to just keep things simple.
What is the background on this tractor? Did you just purchase it, was it a family heirloom thats been sitting for a long time until you started to get it going? What did the previous owner say about it? The reason ask, is starting from the most basic things first and working your way up to the more conplex problems. If its been sitting, you may have bad diesel in it causing it to not fire up. Are you pre-heating the glow plugs properly before trying to start it. My 7200 requires i turn the key the opposite direction for about 30 seconds or so before cranking it over. Im not sure if your machine is similar or not. Is the air filter extremely dirty, fuel filter plugged up? When you crank the engine do you get any puffs of smoke coming out of the exhaust? If you do is it white smoke or black? Also is this an HST or gear model? If its an hst i read it may have to be shifted into the neutral position to start.
The fuel cutoff switch was another recommendation to ensure it fires. Engines need 3 things: fuel, air, and spark or in our case heat and compression. If the fuel system has been opened up at anypoint. Diesel engine run at high pressure, if any air has been introduced into the system it would need to be properly bled to get the air out.
If the fuel pump is mechanical, turning the key on shouldnt pressureize the system, cranking the engine would
