RPM for bush hogging
figjam
b8200
Nov 11, 2009
11
Ocala,fl
my RPM meter says almost 2600 to run the PTO, that seems really fast for a diesel? It doesn't seem to cut well unless it is up there but I hate running it that hard?
Steve H
Kubota B1600
Oct 31, 2009
12
Virginia Beach, VA
I am not an expert but I have cut some brush. Mostly high grass not too thick. I have run between 1800 and 2000 RPM's. It seems to cut good.
L4740
222
3rd Rock From The Sun
Most of the newer Kubota's HP rating are around 2500 - 2700 rpm. So I don't think that is too fast. My L4740 runs right around 2600 at 540 pto rpm. I always try to run my attachments at 540 rpm. There are exceptions of course.(ie: post hole auger).
But attachments like mowers, bush hogs, tillers, I always try to tun at 540 rpm. They just seem to perform better at their rated speed.
P.Holm
L2250 4WD,FEL,60"belly mower,60" JD bush hog,60" JD box blade-Kubota T1400
Apr 24, 2009
38
Lakeland,Fl
I aways felt that running mine at 2500 rpm seemed high as well so I run my bushhog at about 2000, I'm sure 2500 is fine but I always try to cut down on fuel consumption.
My neighbor swears by running his at 1500 ,but I never got good results from that.
Paul
eserv
BX24, A1000 Kubota Generator
May 27, 2009
2,140
139
Hardisty, Alberta
If you are working your diesel engine it is always more productive and easier on it to operate it close to it's rated speed rather than lug it down. 2600 rpm would be fast for some diesels and slow for others, your engine is designed to be most productive and efficient at that speed.
Ed
figjam
b8200
Nov 11, 2009
11
Ocala,fl
Ed
Hmm, guess the manufacturer knows best. good comment thx.
Bluegill
Jan 11, 2012
1,560
Success Missouri
I run enough rpm so the engine isn't lugging down. Around 1500 for the old 3750 and 1800-2200 for the L3800. Sharp blades are the trick in thick tall grass. Less fuel use also. ;)
76_Bronco
B7200 4WD w/FEL, 4' disc, 4' Brush Hog, 14" Plow, 4' Blade, JD 246 2 row Planter
Mar 28, 2012
182
Rainsville, Al
It really depends on the size of your bush hog and how fast your traveling. My B7200 easily handles a 4 footer @2200 RPM in 3 low, and I can get 4 hours out of a gallon of fuel.
Kingcreek
Grand L3010 GST 4wd, LA481FEL, various attachments and accessories
Aug 3, 2011
457
NW Illinois
If its meant to be run at 540 PTO then that's where I would run it. My tach has a white arrow indicating 540 PTO at 2500 engine rpm.
TripleR
Sep 16, 2011
1,911
SE Missouri
I run all of mine at the 540 recommended RPM.
