Mower deck wont go down
Gremlin2034
B2620
Sep 15, 2022
Pennsylvania
Hopefully someone can help me here. I am running b2920 with mower deck. The mower will go up with no issues when trying to put it down the lever feel hung up an wont let the deck drop. When i shut the tractor down it still wont drop unless i pull up on the lever like 10 to 15 times since it goes down in slow increments. I looked an made sure that knob was in the right position below the seat that was ok. So what is my issue?
jnschnit
B2601, BH70 BH, LA435 FL, RCK60-32 MMM, BX2763 Blade, ZD1011
May 10, 2013
135
45
newark valley new york
The mower raises and lowers with the 3 point hitch. Don't know if you were talking about the mower height adjustment knob or the or the lowering speed knob. See attached pic
If the 3pth goes up and down you will need to check the linkage for the mower deck to see why its not dropping.
4,860
Something is binding, and it will be up to you to figure out what. Usually, as a result, the mower deck is out of alignment, or a linkage has been damaged during use.
