Trapper Bob
I was cutting trees in my pasture. I went to pick up several with the grapple. 1 slipped & ended up hitting the front tire, then rolling against the side of the motor. Not sure how it missed the plastic side cover & hood, but did break off a bolt that was holding a bracket with 2 wire bundles in it. This is on a 2018 L 4701. Unfortunately, the bolt didn’t break, the threaded pocket cracked & the threads stayed on the bolt.
Thinking about filling in the pocket with JB weld, drill & thread the pocket again.
Or make a stud to JB weld into the broken pocket. The stud would have the proper threads inside it. Shorten the spacer & bolt, then reassemble. Or make a stud to JB weld into the broken pocket. This stud would be cross drilled to allow me to Zip Ty thru the stud, to the wire bundles. I believe the original bracket was controlling the wire bundles. It would be expensive to replace the gear case.
All ideas or opinions welcome.
