Reinstall loader when not level with tractor
Danl1957
Bx2380, fel, rear blade, mower, winch, JD 318, HD road king, sportster, boats
Sep 12, 2022
19
Vermont
Hello to all,
I am the new owner of a bx2380 and recently removed the quick attach la344 loader, when attempting to reinstall the loader, I find it is not level with the tractor and the mount hooks will not close locking the loader to the frame.
Can anyone offer suggestion for this situation?
Thanks in advance
TheShadyKubota
2021 BX2380
Apr 1, 2022
108
81
Manitoba, Canada
I made the same mistake the first time I took mine off this spring. I just had to man handle it a bit and use some leverage with a breaker bar to line them up properly. Since then It's always taken off in the garage.
rc51stierhoff
3,071
Normally shim under bucket is for valve adjustments 😉, but maybe this would be an exception…or shim tires on tractor until you get the machine and loader aligned…be some trial and error.
Danl1957
Sep 12, 2022
19
Vermont
Great, thanks, I will try that. I assume you used the breaker bar to move the loader?
Danl1957
Sep 12, 2022
19
Vermont
Thanks, will try that after work
3,547
2,001
Unfortunately I grew up without cell phones and without the internet. My dad would just tell me "if you created the problem yourself you can fix it yourself".
I wonder if I was growing up these days would he have said "go watch youtube videos and ask anonymous strangers on user groups how to resolve your predicament".
pokey1416
Jun 24, 2020
556
825
SW Michigan
I'm not sure on your model but on my GL I found that sometimes I pushed the cylinders forward and I just couldn't get things lined up to get the FEL back on. Once I realized that I needed the loader frames at an angle, everything dropped in. To do this hook up the hydraulics and use the joystick to extend the cylinders, thereby allowing the bucket pivot to rock it into place.
I keep telling myself that I'm going to spend a day taking it on and off to practice, but haven't done that yet. I sure like being able to maneuver without it on.
Good luck.
Orangeglow
2015 BX2370
Jun 19, 2014
331
151
Prescott, Ontario
Once I get close enough to the bucket to be able to hook up all 4 connectors, after relieving all the pressure in the control unit by moving the joystick to all possible positions, I hook up the 4 connectors, and then use the hydraulics to move the bucket around to help jockey it into the correct position, to be able to install the 2 pins to lock it in place. Once you go thru the pain of having to struggle to get it back on the tractor the first time, you soon realize that the next time you take it off, make sure it is on a nice flat, stable surface.
jkrubi12
B2601/LA435/QA54"/BH70/B8160box/BB1254/PFL1242/SGC0554/WC-68 Chipper
Sep 24, 2012
397
289
right coast
Neil to the rescue! Again! :ROFLMAO:
Danl1957
Sep 12, 2022
19
Vermont
Thanks, I agree with your dad, but YouTube videos are so helpful,
