Lx2610 w/cab - wheel spacer size and any info please!
Freeheeler
b2650 tlb
Aug 16, 2018
706
527
Knoxville, TN
I also went with the 3" Bro-teks. Easy install, give a good looking stance, and add noticeable stability on slopes based off of my butt pucker inclinometer readings.
jrsavoie
2022 LX2610, 1963 JD4010, 1975 Ford backhoe, 1996 Toro 223D, 1999 Toro Groun325D
May 3, 2011
155
34
Clifton, Illinois
Great advice, thank you. Bro-tek recommended 3" and Bora's recommendation was 2" on all 4 corners. Bora has a 8 week lead time, bro-tek has 2" and 3" in stock.
AND NJtool reports Kubota sells 1 & 3/8" for this machine...
So I'm thinking front spacers probably aren't necessary and trying to decide between Bro=Tek 2" or 3". They don't stock 2.5". Do you agree?
AM i being to paranoid in thinking 3" may be to much based on Kubota selling 1 & 3/8? AM I overthinking this and do yo agree fronts don't offer enough return on investment?
Geez, now even I'm confused! Help me out with a dope slap if necessary please!
The front spacers cut down on the tricycle effect. It's why Suburbans had wider fronts than rears.
Tricycles or narrow front tractors. Are very tippy. Had 2 friends killed mowing with narrow fronts.
I heard front spacers were not recommended for the LX2610.
I don't know why not and would like to order some. If there is no good reason to not do so.
jrsavoie
May 3, 2011
155
34
Clifton, Illinois
Thanks for this post btw. Just ordered the BRO-TEK 3" rears for my LX2610 w/cab. I saw they even have a 4", tho I went with your suggestion, 4" seemed a bit extreme.
I need to measure and see what might work with 30" rows.
jrsavoie
May 3, 2011
155
34
Clifton, Illinois
Do you have torque specs for the installation?
Does that butt pucker have a grapple?
Freeheeler
b2650 tlb
Aug 16, 2018
706
527
Knoxville, TN
I don't remember the torque setting. My son looked it up on his phone, set his fancy digital torque wrench, and handed it to me to.
No grapple, I use forks and finesse ;) Pretty sure the butt pucker values will apply to grapple work as well.
BlueMule65
LX2610
Jan 6, 2023
Kentucky
Has anyone experianced issues caused by the added stress on the axel? I'm looking at 2" spacers for an LX but don't want to cause damage to the tractor.
je1279
Dec 6, 2020
828
585
Upstate NY
I have not heard of any issues when installing them on the rear axle. Additionally, I never got around to installing mine and they are currently for sale if you are interested.
Jack@Northeast
LX2610HSDC
May 15, 2021
39
38
Natick, MA
150 hours on mine, no issues whatsoever. Would not even consider removing them at this point.
morrisosu
LX2610HSDC
Aug 1, 2022
Oklahoma
I'm at about 50 hours so far and no issues. It really helps when on even the slightest of hills. Worth it IMHO.
cthomas
LX2610 HSDC
Jan 1, 2017
850
563
La Farge Wi
290ish hours on mine(2" spacers) with no issues and backhoe has been used with them on the tractor.
je1279
Dec 6, 2020
828
585
Upstate NY
I am interested. Are they aluminum or steel?
To be honest, I am not certain but based on their weight, I would assume they are steel.
je1279
Dec 6, 2020
828
585
Upstate NY
I see on their site that just about every model has its own part number. May be model specific?
I looked back at my order email and it just states Kubota LX2610 Rear 2" Spacers.
Concept Automation LLC
B2650HSDC, BH77
Mar 12, 2026
46
10
New England
good advice, thanks
Well, these are old posts, and I'm still waiting on delivery on my use B2650HSDC / BH77, first Kubota.
On Rear Wheel Spacing , the old Ford 1910 I'm replacing has Huge Rear Turf tires I put Beet Juice in. Has quite a wide rear footprint, and stable on my slopes. Have a backhoe on it as well, so lots of rear weight.
Will put the B2650 side by side with the Ford before it sells, to compare rear width. If needed, I'll get rear wheel spacers, as the B2650 has the R4 not Turf tires.
