I replaced the radiator, water pump, fan and thermostat on my m9540 Kubota. The tractor sat for over a month while waiting on parts and doing the work. When I got everything installed I was ready to crank the tractor, service and get to work. The tractor would not start. The battery is charged and all connections are good. There is no power to any of the terminals on the switch. I checked all of the fuses under the steering column and the master switches under the hood. All are good. I also have power on the starter and alternator at the battery wires. A friend of mine thinks I have a blown fusible link. A mechanic I talked with said I could have grounded a hot wire accidentally and caused it to blow. He did not know where it might be located. I have looked and can’t find anything that looks like a loop or fusible link. Have looked on the internet and can find no help in locating it. Any suggestions about where to look or other problems I might investigate would be a great help. Thanks rl
