M9000 PTO question
Appling-Farmer
9
Appling, GA
I am having an issue with the PTO seal on my M9000. My seal came apart. I have ordered that little $42 seal and should be in today. However, I would like to rule out a worn bearing. Any idea how much play there would be on the PTO shaft without the seal? I am able to move the shaft a little (1/4 inch or less.) I was using the baler when the seal come apart and want to rule out major damage.
dvcochran
Kubota M9000, New Holland TN90, Deere 2640, Vermeer 504N, Vermeer 504SI, more
Feb 23, 2011
212
45
Dickson, TN
I do not know the exact spec but 1/4" sounds like a lot for any shaft/bearing assembly. It the outer bearing pushing against the seal? In other words, did the seal fail from the inside-out
Appling-Farmer
9
Appling, GA
I wasn’t sure how much support the seal held. I will check out the bearing a little closer.
Captain13
Feb 27, 2019
516
169
Kathleen, GA
1/4 inch is a lot of play. That will take out a new seal pretty quick.
3,323
