BX2200 rear axle seal replacement
botietruck
BX2200
Jul 19, 2012
Chesapeake, VA
Hello, I'm new to the board and I am having a problem with our BX2200. The outer right rear axle seal is leaking and I have ordered the parts to repair it. Does anyone have any tidbits of information on this tractor as far as replacing the axle seal? I will be tackling it this weekend. Any info./advice is appreciated.
botietruck
BX2200
Jul 19, 2012
Chesapeake, VA
Thanks for the parts breakdown. Do you know what I will have to do to get the axle out? I'm thinking I'll have to go through the rear case somehow.
eserv
BX24, A1000 Kubota Generator
May 27, 2009
2,187
170
Hardisty, Alberta
Axle seals are a very big job on BX tractors! You have to remove the whole transaxle from the frame to get the final drive housings out. It will wreck your whole weekend and probably then some and I wouldn't even attempt it without a service manual! Thankfully we hardly ever see them leak!
Ed
Kytim
B6000DT, B7100DT,Snowplow, RM360, Scoop, Cultivator, Carryall,Disk, plow
Aug 14, 2009
848
Western Ky
Well there you go, two service techs have chimed in. I learned something about it, hope you have a swift and easy job of it.
Good Luck!
davesl708
BX2200, LA211, RCK60B-22BX, 5ft. Rototiller, Rear Blade, 4ft Drag Harrow
Feb 24, 2013
40
Shawnee, Kansas
I am late to post on this issue just wanted to share what I found on my 2003 BX2200 rear axle. 1187 hours on it
I had oil leaking down the inside of the rear tires. I thought great a tear down to replace the axle seals. Closer inspection revealed the seals were fine. The plastic housing to fit the seals into the axle housing was the culprit.
Instead of a tear down I removed the rear tires. Drained the trans. Then pulled the plastic mount loose. Cleaned the mount and axle housing with brake cleaner. Then applied red RTV sealer to the plastic mount and reinstalled. Let it cure for a day then refilled the trans and problem solved.
Two years and 100 hours later still no leaks.
10,707
How about using these "stop leak" transmision aditives - would these be of any help?
No, avoid using them period, they just thin the hydraulic fluid (that's what's in there).
ipz2222
L235, bx2670
May 30, 2009
1,927
chickamauga ga usa
They are not " thin hydralic fluids", they are chemicals intended to make rubber seals expand. Problam is , they make all seals expand, causeing other problems.
