Hello All,
Picked up an FL850 Tiller, after searching for 3 years, for my B5100 and got around to getting her all painted up. Just need to add oil and she will be ready to go! Except for this little issue. Obviously I saw that PTO shaft was extended by previous owner, must have been on bigger tractor, but didn't think about it until I hooked up tiller to tractor. Stupid me. Anyways, Kubota doesn't sell this anymore. The yoke is a smooth bore and keyed. That's what the end of the splined shaft is like and held in place with a key. Anyone know what else might use this shaft size and spline? Otherwise will have to cut it and reweld it right to the bottom of the yoke.
Also, when tiller is lifted all the way up the outside sleeve actually bottoms out on tractor yoke side as can be seen here. Seems weird to me as this tiller was made for this tractor. I am going to have to cut the outside sleeve back probably an inch because new weld will prevent it from telescoping all the way like its supposed to. Thanks for the help!
