I’m looking for some help to lower the idle speed on a kubota v2403 that was used in a Lincoln welding machine. It has a low idle and high idle feature. Low idle rpm is 1400. High idle rpm ranges from 1450-1600 controlled by a potentiometer. The set screws located on the injection do not move when rpms are changed. I believe it all controlled by the fuel shut off solenoid. Any help would be much appreciated. Thank you.
