L185/1200 FEL removal
Deuxdiesel
L185DT
Jun 30, 2021
SE MI
I am going to remove the entire 1200 FEL from my '74 L185. I can't figure out what to do with these hydraulic supply lines. Do I need a hose to loop them together? Was there a block-off plate from the factory? Any suggestions would be appreciated.
007kubotaguy
B7100DT L245DT JD 2355
Dec 23, 2012
645
257
Herald Calif.
You'll want to Loop the lines. Or you could put the original block that did the same. If you need one I can supply you with one.
1,420
There are two o-rings between the blocks that you may want to replace (but the old ones will probably be fine). Dealer can get them easily and they are not very expensive.
Deuxdiesel
L185DT
Jun 30, 2021
SE MI
Thanks, I will look out for those. If I can get a block off plate I will be all set. I suppose I can just get a loop of hyd hose made as well. Not sure of the thread pitch on those.
1,420
You can get a block made or modify the one you have or just loop the hoses but don’t just plug the holes in the block or you will dead head your pump and mess it up.
