PHPaul
After spending literally years looking for an inexpensive yet effective way to mow ditch banks, I finally stuck a crowbar in my wallet and sprung for a Sabre Samurai.
I have a B2650 with a rear remote and hoses plumbed to the front for a thumb. The immediate plan is to use that to power the hydraulic motor on the mower.
However, I have some reservations about that as a long-term solution:
1. Will the flow be enough?
2. It seems the motor on the mower is sensitive to speed - several references are made to throttling back the tractor to keep flow to the motor within specs.
3. Not thrilled with cycling the temperature on the tractor hydraulic oil, altho with a hydro transmission, I expect it runs pretty hot anyway. Issue?
4. Not thrilled with tying back the lever on the remote valve as a way of activating/deactivating the mower.
As I said, probably ok for a temporary hookup. I'm thinking of an alternative for long-term as follows:
I have a Prince PTO pump off a log splitter. I'll have to come up with a tank, but thinking the PTO pump with a flow control valve would be a better option. I have enough fabrication skills and equipment to make a 3PH mounted assembly to hold the tank and associated plumbing and I have hoses already plumbed to the front from the rear remote with quick connects on them. Already using them to swap around to meet either front or rear mounted hydraulic requirements.
Assuming I can put a flow control valve on the pressure side of the pump and plumb the return line direct to the tank. Hoping a big enough tank (5 gallons?) will be adequate for cooling purposes.
Am I missing anything or completely off-base here?
