A beveled backhoe bucket is beautiful
Mark_BX25D
Bx25D
Jul 19, 2020
1,781
1,301
Okay, well, it's not beautiful, but it sure works better.
I've been doing some trenching with my backhoe to re-route my well line and add some outdoor irrigation points (frost hydrants). Running into a lot of small roots, like half to 1 inch buggers. Occasionally bigger, but run into a bunch of those smaller ones together and it can slow things down with a small machine like the BX25.
I took a look at the bucket, got out my angle grinder, and beveled the edges of the bucket. I saw a significant improvement in my digging speed. Seems like a small thing, but it made a very noticeable difference. Part of the difference was cutting through roots, but part of it was just cleaner trench walls, which meant less time spent cleaning out loose stuff.
Definitely worth my time to do the beveling. If I had to do it over again, though, I'd put the bevel entirely on the inside. I think that would work even better, keeping the "cutting" edge to the outside of the bucket.
ejb11235
BX23S, Braber BBR4G 4'BB & LRM5G 5' rake, Redline 48" rock bucket, PFL1242
Jan 20, 2022
486
373
Seattle, WA, USA
That's clever. Definitely something to keep in mind if I run into this problem on my BX23S.
5,175
I can clearly see the bevel, but it is not at all obvious that is a BH bucket.
5,695
hmm....The 12" bucket on my BX23S is already beveled. It also has 3 teeth which makes digging go a lot faster than a 'trenching' bucket.
5,152
The material that you are digging in is what makes the difference. I have no problems digging in sandy soil, but when I encounter large rocks, a small tractor is no match for them.
Mark_BX25D
Bx25D
Jul 19, 2020
1,781
1,301
Sounds like the same bucket. but mine came with a very flat edge.
My 16" bucket has 4 teeth, but the edge below them (the lip of the bucket) is a 1/2" square edge. I'm currently using it without the teeth to backfill my trenches. Works very well, because it doesn't dig in much. Makes me wonder how much better it would dig if that edge were beveled. I plan to find out next time I do a trench, which should be next year.
Freeheeler
b2650 tlb
Aug 16, 2018
706
525
Knoxville, TN
I have a ripper for bigger roots, and the BH77 powers thru the smaller roots pretty well, so I've not bothered to cut a bevel before. Your comment on it leaving a cleaner side wall with less loose dirt clean up makes sense. I will definitely try that out, thanks for the heads up.
5,330
Agreed. My 16" bucket is as sharp as a block of wood. Makes for a crappy looking trench. I've wondered if Kubota sold side cutters for the bucket and "chisel" teeth. There's much room for improvement in their choice of bucket design.
3,095
I think all of my B670 buckets are beveled on the sides, on the inside, but not to the point of being sharp.
I don't think it would take a lot of effort to get them sharp, but I think the effort would be lost in the rocky soil I have to dig in. (can't get a clean trench wall anyway because of all the rock pull-outs)
You can clearly see the bevel on the 10" bucket on the ground.
Mark_BX25D
Bx25D
Jul 19, 2020
1,781
1,301
Yes, sharp isn't needed, but sometime less blunt than a square face has made a big difference.
Dieseldonato
Mar 15, 2022
728
439
Pa
Just out of curiosity did you spec a finish bucket for your hoe or is that just what came on them? Finish buckets arnt really made for digging. Kinda like digging a hole with a flat shovel. They Excell at loose material handling a finish/grading work.
5,330
Ok, wrong choice of word in "sharp". I think you guys know what I meant. sheesh.
Mark_BX25D
Bx25D
Jul 19, 2020
1,781
1,301
It's just what came on it. Looking at the Kubota website, I don't see any finish buckets listed.
Dieseldonato
Mar 15, 2022
728
439
Pa
Just so I understand, the flat (finish bucket) came with it. And there were no options for a tooth bucket? Or the finish bucket came with and there are no other options for a tooth bucket?
Mark_BX25D
Bx25D
Jul 19, 2020
1,781
1,301
Mine came with the three-toothed bucket, which is what I beveled. I bought the DR elsewhere.
Dieseldonato
Mar 15, 2022
728
439
Pa
Ok it wasn't real clear in the pictures if it was a tooth bucket or a finish bucket. Cheers.
5,175
Exactly correct!
I searched for a Kubota (branded) finish bucket with tapered bottom edge, and came to the conclusion that there is no such thing.
I have a new 16" Kubota bucket with 3 teeth.
I have ordered 3 extra teeth, as well as a 60" hunk of bucket cutting edge (60" was the shortest length I could find).
I will have a piece of the cutting edge welded to the 3 teeth, and then by simply driving out the tooth pins, will be able to swap between using the tapered edge, and/or the 3 spare teeth.
I have absolutely zero rocks, so only need teeth for occasional roots.
A pneumatic palm nailer works great for driving the tooth pins out!
