Got some loader time in on my new BX23s this weekend and noticed it kept digging in on the right side. After getting it in the garage I noticed the front-end loader is about 1” higher on the left side than on the right. Measuring at the frame (on the front) it’s off about 1/2”. At the back-end the fenders are the same height. Tire pressure in the front is 17psi on both sides.
Dealer said, to adjust the air in the rear tires to make up the difference. I’ve adjusted to 20psi in the right and 14psi in the left and it’s still off. Changing the pressure made little to no difference that I can tell.
Is this normal? Is adjusting the rear tire pressure really the answer here? I didn’t have this problem with my old BX1500.
