FEL won't work
5 kubotas
m7040 cab tractor, RTV 900, GZ20 zero turn, G1800 Lawnmower,
May 9, 2012
Dozier, Al. USA
Two days ago, I removed the front end loader from my 7040 (only 28 hours on it.) I reinstalled it this afternoon and then found that it would only go up about 2'. I finally got it to go all the way up by bleeding the pressure line into the cylinders. I still haven't it to put pressure downward. What is wrong and how can I avoid it happening again?
Eric McCarthy
Kubota B6100E
Dec 21, 2009
5,223
Richmond Va
Double check your hydraulic lines and make sure they are not crossed or see if they are connected tightly into the quick connect coupler.
GWD
M7040, L48 TLB, BX2200
Jan 8, 2010
792
15
Northern California
Eric has it diagnosed. It is a common problem.
Remove all of the quick attach connection and re-seat them. If the lines were reversed or mis-connected then some odd movements will happen.
Also, make sure your 3PH is all the way down in case the lift adjustment has somehow changed.
JOE LOW
b2620 FEL BH RM59
Jun 19, 2012
11
PORT C
YUP!
Did that rookie mistake yesterday ........line" looked "connected......no click no work!
