Fuel supply issues
TomCxyz
tractor
Aug 1, 2022
U.S.
M4030su won't run smoothly or at all.
Have cleaned rust particles out of fuel tank and blown out the fuel lines from tank, fuel filter, and fuel pump.
Lastest evidence is that clean / clear fuel slows freely from exit line of fuel filter but exit line from fuel pump only puts out dribbles and small squirts during cranking. If let sit for a while (~1hr) engine will usually roughly chug and finally run a bit (~10-20seconds) before dying. I think enough gravity fed fuel leaks through the fuel pump while resting ; engine can dstart and run on that amount fuel for the 10-20secs.
Question :
1) How to test fuel pump ?
2) Should shop air into fuel pump exit port flow freely ? It doesn't, but does flow freely through pump inlet hose.
3) What would be typical failure modes of the fuel pump ?
2020 BX23S, Threatened and Intimidated into silence.
5,150
You should clean the entire fuel delivery system before you do damage to your fuel rail and injectors. That is when it really gets expensive to repair.
TomCxyz
tractor
Aug 1, 2022
U.S.
Yep, fuel pump must be bad.
I presume that it's a diaphragm pump and that there could be possibility that fault is with the pump driver cam on the engine. Yet I'd also guess that the more likely failure mode is internally in the pump.
Anyhow, have been contemplating replacing with an electric pump. Researched that a bit and can see that low pressure electric pump is very affordable. Not sure what the stock mechanical pump nominal pressure is.
https://ebay.com/itm/154610992472
Universal 5-9 PSI Electric Fuel Pump Inline Gas Diesel Pump E8012S 12V Car Truck
I'm uncertain if a pressure regulator and recirculation plumbing is necessary.
https://amazon.com/gp/aw/d/B09C5TG14P
Universal Adjustable EFI Fuel Pressure Regulator Kit
A pump with built-in recirculation port would be desireable.
2,958
1,630
Yep, diaphragm pump just like a '50s Chevy but smaller. You can use the electric pump, many newer Kubotas do. Just need to wire it to 'key on'. Should only need 5 - 10 psi, no recirc needed. The smallest available should be sufficient.
5,437
The OEM pump is about 60 Canucks.....
might be cheaper than 'bodging' and electric one in ??
at least it'll fit first time !!
loggin
MX4700
Sep 4, 2021
104
38
canada
Please remember to check your engine oil!! Mechanical diaphragm pumps are notorious for dumping fuel into the crank case when they fail. Switching to an electric fuel pump prevents that from happening in the future.
JerryMT
Jun 17, 2017
529
156
The Palouse - North Idaho
Question :
Which pump are you talking about, a lift pump or the Injector pump (IP)? Lift pumps sometime have screens that are cleanable but they can fail and they generally add 4-5 psig above the gravity head to the IP inlet. If you lift pump inlet isn't clogged than it probably failed. If it's the IP, check the inlet port for a possible clogged screen. Don't forget to check the fuel lines for debris.
TomCxyz
tractor
Aug 1, 2022
U.S.
Talking about the lift pump.
I haven't stumbled into fuel line screens yet, but thanks for the tips. I'll check the oil too.
JerryMT
Jun 17, 2017
529
156
The lift pump is a mechanical pump, usually a diaphragm pump. If it's working, there will be a big stream of fuel shooting out when you crank the engine. "... dribbles and squirts..." means it is not working IF the inlet is not blocked.
