Looking for b7100 parts.
Mountainman
L2501, B7100, B6000, B21, B1750, B2400, B7200
Jul 10, 2022
228
80
Attalla Alabama
mossycreekoutdoors.com
Anyone parting out a b7100 looking for a few parts.
6 lug 12" front rims ( believe few other models would work too)
Hydraulic diverter block standard oem not one made for using attachment
Thanks
4,486
Thanks
The OEM hydraulic outlet block is NLA and there is no added value in it. Its just a chunk of metal with some ports in it and the shop made ones are cheap, readily available, and work just fine.
Mountainman
Jul 10, 2022
228
80
Attalla Alabama
Do you know where I can find one? I'm removing a loader from one and need the regular block to replace it
4,486
I see - you want to replace a diverter with the blanking plate.
If you advertise you can probably find a blanking plate but you can simply plumb the two ports in the diverter you have together,
Making the blanking plate is easier than making the diverter. If I was not up to my neck in work I would make you one.
Mountainman
Jul 10, 2022
228
80
Attalla Alabama
I appreciate it. I'm going to use the Plate and loader on another tractor and sell this one. I could use the block from the other tractor but it'll be a while before I make the change
