New member, frustrated by recent hydraulic issue.
We had an urgency to attach the BH (BT 600) and dig a smaller animal grave (imagine the tension!, and the mood). I got the BH attached and once in the pasture, I noticed a hydraulic leak under the BH. I tried to rush, and in the process had to refill the hydraulic reservoir a few times (the leak was healthy).
I was able to finish and get the BH packed up, and the FEL worked fine to cover the animal. I drove the tractor out of the pasture, it drove fine.
Now, I identified the hoses, and replaced them, and have added nearly 2 gallons of UDT2 to the reservoir to get the level on the dipstick.
So, here's the issue (with the engine rpms above idle) ...... the FEL operation is erratic (but will raise/ lower, tilt) , not the smooth operation I'm use to.
The BH is unresponsive.
I lowered the mower deck, and now it will not raise.
I apologize if this is addressed in another post/ thread, the tractor is needed again in a few days, and honestly I'm just too frustrated)
Thanks for your time!
