Hello, I just found and joined this forum. I'm hoping somebody can steer me in the right direction. hahahee <whew>
I fired my L2900 GST up and took it about 10 feet when I realized I had no steering to the right. I still had steering to the left. Here are the specific symptoms:
I do have the factory workshop manual which I have been studying intently...
Please note my GST tractor has the hydrostatic power steering. I pulled off the covers under the steering wheel to expose the Steering Controller and the hoses look fine with no signs of leaking.
The Hydraulic Pump and Regulator Valve as viewed from the right side of the motor also look clean and dry.
The major leak with the steering turned right appears to be coming from between the Steering Controller and Hydraulic Pump, streaming down the side of the transmission case.
I can't see the hoses at all. I can't believe they are in there so tight and deep, especially for something that should be readily serviceable. They drop from the Steering Controller through a boot and behind the firewall hump before finding their way to the Hydraulic Pump area. When I was trying to get in there to see what I could see with a flashlight, I did see a rat's nest up in the same firewall area. I'm hoping my issue is a hose that's been chewed through. I poked and prodded with the longest screwdriver I have and got some of the nest out but like I said, it's tight!
My question is two-fold:
1. Am I on the right track in thinking a loss to steering in one direction should be traceable to the Steering Controller or could there be another issue somewhere in the chain?
2. What's the best way to access this area? Is the floorboard (deck) easily removable? That looks like the best way to see what's going on. I can't see or access anything from below.
Thanks for your help!
Randy
- turn to the right = massive leak and no wheel response
- turn to the left = operation normal, no leak
- powered down and steered left is fine but with no PS
- powered down and steered right = no response
- transmission, loader and rear hydraulics all operate as normal
Randy
