Not a lot curling power
BruceMyers48
L3901, 6' Boxblade, 6' Mower
Nov 9, 2014
35
Zephyrhills, FL USA
I have a L3901 and I do notice when going into a pile of dirt I have to back out a bit to curl dirt into my bucket. Don't seem like a lot of power trying to fill my bucket. Thanks
Yooper
3901 LA525
May 31, 2015
1,647
790
NE Wisconsin
Not much help here. On mine it is just the opposite. More power with the curl than with the lift. Maybe a weak cylinder? Might want to do a pressure test to see if you are getting some bypass in one of the cylinders
5,368
That's not unusual. You can readily stall the bucket with heavy material like dirt or stone.
woodman55
L6060HSTC, RTV 1100
May 15, 2022
1,050
868
canada
My L6060 is the same way. The curl linkage/pins are too close to the hinge pins. They are designed this way to keep people who don't know what they are doing from damaging the equipment. It also gives more curl travel.
OrangeKrush
Nov 15, 2020
1,044
516
Indy
Get higher up on the pile if able to so you don't have the weight of the whole pile resting on bucket.
edritchey
Ferris IS800Z - New Holland WM75 - John Deere X500
Jul 19, 2014
1,121
827
Wellsville, PA
What you are experiencing is normal for new operators you will get better at it as you get used to your machine and it's capabilities.
6,930
Many Kubota loaders don’t have a simultaneous lift/curl function. They really do, but it can cause some funky response if joystick isn’t feathered correctly.
Like Ed Ritchey said, a little practice can go a long way.
Note the 7 o’clock position on my loader. Lift/curl is black/not available. It will lift and curl. Just need to get it right.
5,368
Lift and raise works on an LA525 and frankly I was using it long before I realized it was missing from the label on the loader. According to my LA525 Owner's Manual the reason for that empty position in the label is:
Note:
The lower left position (Raise and Rollback) is not recommended because of insufficient lift force
6,930
Dan - same here for my little LA243. It works, just need to hit it right.
Not to venture away from the thread, but someday I may look for some help/expertise from you for the hydraulics of my old timer. Not today; that’s for another time
All’s well and workable, just needs some TLC typical for a 69 year old….hoses, fittings and a better understanding of the pump and system. Pretty rudimentary. Think I have it okay, just another set of eyes.
It’s been a part of me my whole life…. I still don’t drive my new truck without my thumbs on the outside of the wheel…..
Couple years ago, Magicman deemed it an honorary Kubota. ;)
Now back to your regularly scheduled program……
5,368
All’s well and workable, just needs some TLC typical for a 69 year old….hoses, fittings and a better understanding of the pump and system. Think I have it okay, just another set of eyes.
Skyline loader?
BruceMyers48
Nov 9, 2014
35
Zephyrhills, FL USA
I have been operating Heavy equipment for 35 years and the l3901 for 9 years, the powerless curl has bugged me for years, Trust me I have moved ton of dirt with this tractor but the power to dig and fill bucket with out backing out a tab is a pain
BruceMyers48
Nov 9, 2014
35
Zephyrhills, FL USA
Note:
I have place the blame on the L3901 not having the lift power for the weight going into a pile of dirt, I'm use to running a full size cat loader and a 670b john deere grader
6,930
Skyline loader?
Dan - I honestly don’t know. My dad and grandfather bought it used at auction late-‘50’s. Except for hoses and cylinder repairs, haven’t dealt with manufacturer to my recollection. I’ll ask Dad if he remembers.
It does have a frame/rail mount issue at the rear axle. Would be good to know what original looked like. It’s solid, but was a farmer repair/improvisation from decades ago.
Sorry Bruce.
5,368
Sorry Bruce.
Just my first impression based on the curved lift arms - a distinctive feature of the Skyline (Davis) loaders of that vintage. Made for and retrofit to a lot of different old iron.
6,930
Bruce - while I don’t have the experience you do, I never recall this lift/curl issue with any industrial loaders I’ve run.
Not a ton of seat time, but I’ve run commercial TLB’s many times, and oscillating wheel loaders quite a few.
Never an issue as I recall.
Apparently, some other compact tractor manufacturers have less multi-functionality as Kubota. If I remember correctly, some of the green ones can only do one function at a time under some circumstances. No experience, so I could be speaking out of school.
5,368
Uhhhh - its a lightweight quick-attach agricultural tractor loader not earth moving equipment. It won't breakout a bucket buried in heavy dirt and it won't pick up 2000 pound rocks. The first thing I did with mine was move 10 tandem loads of heavy rocky fill and I was happy as a lark with the performance. It was quick and easy to use and easily moved full buckets of that heavy material once loaded.
BruceMyers48
Nov 9, 2014
35
Zephyrhills, FL USA
You are probably right, I will deal with it, not a big deal, thanks for you advise
troverman
Jun 9, 2015
1,178
264
NH
I've had a number of Kubota tractors with loaders, my L2501 with this same loader was a bit of a disappointment as well. So too was the LA805 on my L4060...not nearly as strong as the LA1065 on my previous MX4800 nor even the L4310 from years ago.
