Another grease thread, but for the MMM
tractormd
12
Maryland
I know there are many grease threads, but most pertain to the FEL rather than the MMM. The manual for my BX says to use "multipurpose EP 2 grease." I use Kubota's moly-lithium grease on the loader but understand this is not appropriate for the MMM because of the high speed/temps involved in the mower, correct? I have a ZT mower that uses HD lithium complex grease. Could this be used on the MMM? Or do I need to buy the polyuearu? Thanks for the input.
2,965
If I were concerned, I would use the type of grease the manufacturer recommends.
That being said, and me not being smart enough to question things, I have just used the same grease I use for everything else, on my BX MMM over the last 18 years without issues...that's about 1500 hours on the tractor, mostly mowing...I do try to grease a lot every ten hours of use though.
wgator
L4701HST, FEL and other stuff.
Jul 28, 2018
482
147
NC
Don't know what grease your operators manual calls for but like the hot sauce commercial says "I use this sh#t on everythng". Its polyurea based.
1,415
Just don’t mix grease types (that are incompatible) and avoid high volume molybdenum grease on anti-friction bearings to avoid sliding damage on the rolling element of the bearing.
Dieseldonato
Mar 15, 2022
728
439
Pa
Think the rule of thumb was nothing with more then 5% Moly content if you were using it for an everything grease.
