Fixing tweaked B2650 SSQA in the cheapest way possible
BetterThanAShovel
B2650, BH77, SG0660 grapple, pallet forks, Bobcat 60" box blade
Oct 5, 2021
133
Well, if you saw my previous thread about the grease fitting, I told you my next issue wouldn't be QUITE so easy to fix...
My used B2650 is wonderful, but does come with a few issues I'd like to correct. The current issue is the SSQA, which as you can see in the picture, has the "feet" out of alignment. My goal is to try and fix it.
So, wrong answers include:
  • Buy a new SSQA
  • Cut it and reweld it
If those are the only options, then I'll just live with it like this. I don't like it because it DOES make attaching stuff more difficult than it should be. I sometimes have to step on the bucket or forks to get it to align enough for the pin to latch. Annoying, but bearable.
I did find a video showing them un-bending their SSQA using the hydraulics. Unfortunately, my FEL doesn't have that configuration, so I can't simply mimic what they did....but something like that seems do-able to me, if I can figure out a safe way to do so.
Youtube: Easy way to fix a bent SSQA
Yooper
3901 LA525
May 31, 2015
1,743
922
NE Wisconsin
Just fixed mine about a month ago. Just bumped the forward one against a tree until eyeball straight. Works like new again. Don’t need to overthink this one
BetterThanAShovel
Oct 5, 2021
133
Wouldn't the hydraulics fight against being pushed in?
6,291
seeing that there area 'zillion' videos about the problem it seems to be a 'design defect'. Having only 1 cross bar attachment is 'cheap', relying on the attachment for structural support. I know 'technically' no needed, lowers the weight, increases lift capacity, cheaper to build, higher profit but still seems 'wrong'.
'proper' way to realign would be remove from tractor, mount on flat steel bench, measure and then 'replace the defective steel tube, next way is to just tweak' as required.
BTW it will ALWAYS be weaker after being twisted, nature of steel
hodge
Nov 19, 2010
2,960
531
Love, VA
Obviously not, since it worked for Yooper. You don't have individual supplies to each cylinder; pushing against one will just force some hydraulic fluid into the other cylinder.
Yooper
3901 LA525
May 31, 2015
1,743
922
NE Wisconsin
Yes. That is exactly what you want to happen.
I know how I bent mine. I was using my bucket hooks to lift something heavy and it got off center and caused the left plate to bend forward. Bending it back was easy with absolutely no drama.
7,324
Don’t have SSQA, but see it does happen quite a bit.
Like Yooper says, don’t overthink it.
CGMKCM
RVT-1100C, ZD323, L4760
Jan 26, 2021
471
268
Randolph county N.C.
My SSQA was bent much worse than shown in your photo and could not be straightened
( Photo Left ).
KTAC replaced SSQA and I took damaged SSQA ( I asked for it back and Dealer said no problem) to a local welder that had experience repairing tractors, farm equipment. He had repaired damaged SSQAs several times. In my case we took several measurements off of new SSQA he then cut off the torque tube at loader frame on both ends of tube set everything up on his fixture table and welded in a 2" hydraulic cylinder rod (Photo Center). On the new SSQA torque tbube he inserted a full length piece of 2" round stock and welded round stock to torque tube (photo Right).
I would get your SSQA straight like shown in video or as others have suggested and then sleeve the I.D. of the torque tube with the proper size round stock.
BetterThanAShovel
Oct 5, 2021
133
You are a genius. A little driving into a tree and they were inconsequentially out of alignment. Hooking up the pallet forks was SO MUCH EASIER. Thanks!
And for the record, there's nothing I don't overthink. I think....
pjoh784350
BX23, quick attach bucket, 3 point, pallet forks
May 3, 2019
172
79
Danville
I believe a wise man once said "there ain't nothing bent that can't be unbent!"
nbryan
Jan 3, 2019
1,425
944
Hadashville, Manitoba, Canada
You used a tree, I put a block of hardwood between the disconnected ssqa frame and the loader arm. In a spot that with with the tractor idling, and gentle loader hydraulics dumper lever operation, I could bend the ssqa plate back *just* past straight so it returned to normal position after. The wood block resisted one side moving so the other side could twist back into shape under hydraulic pressure.
