martinlaurentide
Kubota: BX2200, BX2750D, LA211, box; Woods: BH6000, Post Hole Digger-might sell
Update - after flushing a few times, installing the new Kubota thermostat and coolant, runs normally. I need to check the rad a few more times but don't see bubbles nor smoke but that was cut short by a No Start issue that I now, having spent some time on it, need to post separately for more help lol grr... Thanks for the input. Most appreciated.
UPDATE: Fluid is out. That is NOT the drain bolt. On a BX2200, it is located on the Right Side of the (905) engine under the block heater connecting point. Need to find a thermostat. Wondering if this is dealer only or if it and the gasket cross reference with any others?
BX2200, 2001... bought it >10 years ago. Anti-freeze has never been changed since I got it; I should have but missed this on my regular maintenance which I otherwise do twice a year; fuel filters, oil & filter winter / summer, hydraulic fluid and filter sometimes, the screen and rad area (which I did after this occured and yes it was blocked but please read on ...
At first I didn't notice the temperature gauge rising below red but past half so I changed the fuel pump... (suspect for other reasons I won't elaborate on here); tractor got hot, lost power and finally stalled - happened twice before and after that repair. It started and ran after cooling. I will have to worry about damage or not later but suspect it's okay. For now I need to focus on this current repair. Per the heading, I pulled the hose to the thermostat to bring to the parts counter (to be sure...) and fluid was present. I then flushed the fluid from the base of the rad and a couple of litres / quarts emptied. When I opened the bolt to the engine, Nothing came out. It wasn't nasty looking btw, green.
I will still change the thermostat and gasket since they're out but I gather it's the water pump that I need to change which I gather is a bit of a pain. Is there a test i can do to diagnose further from here? Thanks!
