BORA wheel spacers
6,870
2" Bro-tek spacers installed. Ordered thursday, arrived wednesday with monday being a US holiday.
Fitment was great. Only issue I had was one original lock washer spread when I was torqueing the wheels down. I had another one that I replaced it with. We'll see how well they work. Here's a few pics.
install.
done
did anyone feel triggered? ;)
Freeheeler
b2650 tlb
Aug 16, 2018
706
527
Knoxville, TN
Looks like you got that done dirt cheap. My set is supposed to show up today. Hopefully I can talk my son into installing them ;)
5,165
DD how did you get the OEM lugbolts out ?
6,870
Skeets, with the bro-tek spacers (on my machine) you don't have to remove the two studs. There are 4 lugs and 2 studs that mount to the OEM axle flange. If you look closely at the "zoomed in pic" above with the spacer mounted, you can see the OEM studs in the 6 and 12 O'clock position. The 4 other lugs (supplied by Bro-Tek) are the ones that would use a 3/4" socket.
Brotek sends 4 new lug bolts (per side) to mount the spacer to the flange and you use the two existing OEM studs.
They also send you new lug nuts and lock washers to mount the wheel to the spacer. You only re-use the two flat nuts, all flat washers and the new lock washers.
I think the same arrangement is used for the B'01 series as well. No need to pull out any studs.
I just found the installation PDF...see attached
...i hope that makes sense anyway..
Freeheeler
b2650 tlb
Aug 16, 2018
706
527
Knoxville, TN
The online instructions were a big help. After a quick glance at them the whole process took about 20 minutes. Great quality, easy install, makes the tractor look more tractory ;) I'd highly recommend the Bro-Tek spacers.
lakehouse_dreaming
L3901HST, LA525 FEL, RGA1258 tiller, RCR1860 rotary cutter
Nov 2, 2021
59
125
I have looked at wheel spacers for my L3901 and I see that there are aluminum and steel versions. What are the Pros and Cons of each?
NorthwoodsLife
Oct 15, 2021
1,411
1,473
Wisconsin
I'm no professional wheel spacers guy, so take this with a grain of salt.
I ordered the steel ones from Bora (Stahl) mostly for the strength. The weight helps too, but it's just a couple lbs.
Aluminum one's are painted or anodized in orange.
I'll paint my steelies in Kubota gray or orange when they show up.
I'll have a better opinion once I actually receive them.
From what I understand Motortech-Sport makes Bora which is aluminum. And Stahl which is steel.
NorthwoodsLife
Oct 15, 2021
1,411
1,473
Wisconsin
These arrived today. Almost too pretty to bolt on the tractor hub. KIMG0700.JPG KIMG0701.JPG
Rdrcr
Vendor Member
May 7, 2021
756
941
WA
I prepped and painted the Bora steel spacers I installed on my previous B2601. They looked great and the quality was fantastic!
Well worth the investment.
Mike
hilltop329
Kubota 3901--LA525 Loader--5' Bush Hog--6' Bush Hog Finish Mower
May 19, 2022
Missouri
I'm already happy, just from the customer service alone. I already have my receipt, order confirmation, and a tracker sent from ups. The only thing I dread is messing with those filled tires ;)
Just mounted my 3 inch spacers and dreaded filled tires spacers are bora, great item. When remounting tires make sure studs on hub at 6 and 12 o clock top on first nut bottom falls right in place L 3901 tractor
jrsavoie
2022 LX2610, 1963 JD4010, 1975 Ford backhoe, 1996 Toro 223D, 1999 Toro Groun325D
May 3, 2011
155
34
Clifton, Illinois
Skeets, I got my BORA spacers from UTV parts and accessories. With my L3560 cab, it is tippy on the steep hills I have. I got the 3" spacers and they were $320. with free shipping. They help a lot, but I'm STILL extremely careful on the hills and try not to get too carried away going sideways on the hills. I also added a tiltmeter to View attachment 55861 View attachment 55861 View attachment 55862 it to help keep me informed on my angles.
What's your max angle?
Do you have a link to the tilt meter you used? Tilt meter.com
I guess this posted.
jrsavoie
May 3, 2011
155
34
Clifton, Illinois
I forgot to add the picture of my tiltmeter. I got it from the sales section on TBN. As far as the installation goes, I jacked up the side I was working on, loosened the bolts (almost couldn't get them off) and used a pallet jack to glide out the tires and slide them back on when the spacers were on.
Thanks. I was just trying to post to ask what you used.
What is TBN?
5,165
Well I got them Monday, all I need now is some strong young pup to move those filled wheels around,,, hehehee
Kubota_Guy
B2650 FEL SSQA, B7100D FEL
Jan 10, 2024
25
Indianapolis, IN
I went with 2" from Bro-Tek on my BX2680 cause it was as wide as you could go with a MMM. They made a huge difference. They were about $200 with shipping right from Bro-Tek. The company is great and they were almost too nice looking to hide. Going to put 3" on my b2650 soon.
Did you put them on your B2650 yet? (looking to add a pair now before work season sets in!) I'm on VERY hilly land, and lots of side-slope action you can't get away from! My ole' B7100 sat so much lower!
5,188
Well......that post from "angrymatt" was nearly THREE years ago, ......so he has likely either installed his wheel spacers, or has forgotten where he put them!
Kubota_Guy
Jan 10, 2024
25
Indianapolis, IN
Figured I'd get the 3 years later update..... yes their awesome, you should totally do that, or he's under his rig hillside somewhere in greener pastures... ;-)
