Hi all, first time posting on this forum. Hoping to get some insight into whether this is a common issue, or something I should start troubleshooting.
I have a 2009 Zg227 zero turn with a 27hp Kubota gasoline engine. It has about 480hrs on it, and was used for residential mowing its entire life. I purchased it last year, in the fall, and didn't notice this issue until this year (maybe weather/temp related?).
From a cold start, I follow the start up process, of pulling choke, put throttle at half way position, and fire it up, then push the choke back in. Never have any issues when starting it cold. I can run it for an hour or so without any issues, even if I power down briefly while mowing my 1.5 acres.
The issue I am experiencing begins if I shut it off for 10-15 minutes or so while cleaning it off, then go to start it up to put it away. It occasionally puffs black smoke, stumbles like it's misfiring, and can even stall if I quickly push it to full throttle. If I leave it at half throttle, it quickly gets back to normal, but it seems like for some reason, when it's powered off, while hot, extra fuel is entering the combustion chamber, causing it to be too rich on a hot restart.
Note: new plugs, air filter, fuel filters, oil change within last 20 hours of use.
Any thoughts, suggestions, insight would be greatly appreciated!
