Ballast for B2601
Chapel Hill Vann
B2601, bush hog, pallet forks, boom pole, scraper blade
May 1, 2022
29
31
Chapel Hill NC
I recently purchased a B2601 and needed a ballast box. I looked at lots of posts and videos to find out the options and decided what I might need. I wanted about 400-450# total and started figuring volumes and weights. I decided to use a 20 gallon trash can as the base.
I used a standard draw bar for the lower pins and used an accessory top link above. I connected the top link and draw bar with 2 pieces of 1/2" rebar that was bent to shape. I added an extra chain loop at the top for easy lifting. I also added 2 chain saw slots from PVC lumber as well as several sizes of PVC pipes for tool handles. I added L hooks around the sides for chains, a small open pressure treated box for miscellaneous tools/supplies and a 2" receiver for the utility trailer.
After I finished adding all of the metal to the trash can, it weighed 78#. I used 7 bags(50# each plus about 12# water) and the total weight ended up being about 440#. this should be perfect for the 2601 to offset the FEL.
I am trying to decide if I should paint everything or leave it as is.
jimh406
Kubota L2501 with R4 tires
Jan 29, 2021
2,439
1,870
Western MT
That's trashy. Sorry, I could resist. ;)
3,606
Paint the wood leave the can alone,, the unknowing will look at it and think WTH???
ve9aa
Apr 11, 2021
1,200
981
NB, Canada
I really like it ! I'd paint the wood and leave the rest like Skeets sez.
Do you get subzero temps?
ie: do you have drain holes below each pipe for water to flow out?
Chapel Hill Vann
May 1, 2022
29
31
Chapel Hill NC
Yes, before I poured the concrete I drilled holes in each tube/slot and some extra in the bottom. So far, water does not collect.
What color should I paint???? orange, black or ???
JimmyJazz
1,241
765
Pittsburgh, Pa
I recommend an Oscar The Grouch puppet be suitably attached for shits and giggles. Don't paint it. Looks galvanized. I feel the puppet is a must.
ve9aa
Apr 11, 2021
1,200
981
NB, Canada
OMG I love this...I wish I had thought of this !
The only thing I'd add is the cans'"lid" overtop of Oscars head. (for full authenticity)
jkrubi12
Sep 24, 2012
403
298
right coast
Very well designed & constructed. (y)
I like the visible wood grain, I vote for some kind of preservative oil (Linseed?) instead of paint.
Let's see a pic of it on the tractor! :)
