Seeing SUDT2 on Dipstick
chim
L4240HSTC with FEL, Ford 1210
Jan 19, 2013
3,278
2,976
Near Lancaster, PA, USA
When I did the service on my tractor Friday, I was having trouble seeing the fluid on the stick. Typical. I did the brown paper trick before but thought I'd try something different today. A minute or two with some sandpaper on the dipstick created a roughened surface that made it easier to see the nearly-clear oil. Couldn't get a picture to do it justice.
ejb11235
BX23S, Braber BBR4G 4'BB & LRM5G 5' rake, Redline 48" rock bucket, PFL1242
Jan 20, 2022
486
374
Seattle, WA, USA
What grit did you use?
RalphVa
738
322
Charlottesville
The Canadian guy on Youtube in Cluttered Garage says to use a paper towel. Just lay the dipstick on the paper towel to see where the oil soaks in.
Roadworthy
L2501 HST
Aug 17, 2019
1,647
530
Benton City, WA
I don't have a dipstick. I have the sight glass. I use John Deere hydraulic fluid dye. A little goes a long way.
7,318
Chim - that’s a good idea.
Seems like both too little and too much light makes it really hard to see.
3,394
How does scratching up the dip stick surface help? I assume because the rough surface holds more oil, so it is easier to see? Maybe changes the effective diameter of the oil film?
Puzzled but success proves the point that it works.
69 SS
2015 L3901 HST,with Canopy,LA 525 FEL with SSQA bucket
Sep 26, 2015
106
22
Ft. Inn sc
400 hr thing is here,was just thinking about this topic,I just can't see fluid level on dipstick anymore. For sure will do the sandpaper thing. 2015 L 3901 HST . Will also try the shop towel thing. Good luck to all on your projects.
