Not to hijack this thread but I'm having real issues with grease guns. I end up wearing more grease than I get into the machine I'm trying to grease. I just threw away another grease gun today.
I'm now considering a Milwaukee or DeWalt cordless, or the German one Tractor Mike advertises.
Any experience with those types?
YOu don’t explain why you’re dissatisfied with your grease gun…but chances are….the tip was not adjusted properly if it pumped grease everywhere except inside the grease fitting.
Grease gun “tips” are adjustable to fit onto and grab the zerk fittings properly. When people buy them they assume they are “one size fits all” and ready to work.
But think of them THIS way: They are like a ”crescent” wrench. They must be adjusted to “snap” onto a zerk fitting and grab it securely…for grease to flow into the fitting only and not spill grease all over the place. If you look closely you will see that the gun tip is not a single-piece…but is adjustable.
Once properly adjusted….they “snap” onto the zerk fitting and do not leak. A “jerk” should be all that is necessary to remove it. If it does not remove with similar force as it took to “snap” it onto the zerk…then it needs to be re-adjusted.
You WILL find the “happy sweet spot” for it…and will not need any crutches such as lok-n-lub or other expensive modifications.
(The most common reason anyone has problems with adjustable grease-gun-tip is that they have equipment with varying sizes of zerk fittings. However, I keep my gun tips at a medium “grip” adjustment and have no problems with them.
