Hello, I just bought and received a pair of 2" Bora rear spacers for my LX2610. I wanted to install them this weekend but ran into an issue with the size of my sockets fitting into the Bora wheel spacers. The tires are installed with 22mm bolts(4) and two studs with 22m nuts. My standard 22mm socket doesn't fit into the holes in the wheel spacer. I ordered a thin walled socket to see if this would work, however, concerned that the Bora studs and bolts are considerably smaller than the original Kubota bolts and nuts. The Bora hardware is about 2mm smaller. The bora studs and nuts are tapered whereas the Kubota are flat with lock washers. Anyone else run into this situation? Thank you.
