Are pallet forks for a BX2680 even worth it?
dhmeiser
12
Pipersville
I have a BX2680 with quick attach
the spec lifting capacity is 683 lbs
The lightest Quick attach pallet forks are around 250 pounds
so the effective lifting capacity is around 300 pounds
So with this limited lift capacity is this really worth it?
2,540
Typically the "lifting caps" are with the bucket installed - SO if you take the bucket OFF - you should be able to lift a wee bit more since the forks should be less weight than the bucket.
OrangeKrush
Nov 15, 2020
1,047
515
Indy
Sure are! I think my Land Pride forks are 212lbs and they are very handy.
4,887
The HLA pallet fork unit for my BX23S is only 190# and rated for 900#. There's ZERO need to buy a 'heavy duty' unit that grossly exceeds the lifting capaclty of your tractor.You can lift 739# MAX so you don't need one that will carry 1000#. or 2000#.
They are extremely useful ! Put 'stuff' on skids ONCE then move the 'skid of stuff'. I also use as a non-clamping grapple. Once you have them you'll wonder WHY didn't I get them earlier !
None of us are getting younger, the older we get....... !!!
Reactions: 6 users
PaulR
Aug 3, 2020
579
459
Hadley, MA
This x2.
I have the exact same setup. Amazingly useful, can lift a lot more than 250 lbs. Not 1,000, but a lot more than 250.
majorwager
MX5100 FEL ford 1620 FEL International 484 FEL Lull 844C
I have a 8 ft wide X 4 ft deep sq. tube frame w/ expanded metal floor, & fork pockets of course, provides a portable work table @ any height, any location. Must be functional, as it is on loan to neighbors more often than it is available to me.
radas
Mar 21, 2022
719
833
Being able to move brush piles makes it 100% worth it
ve9aa
Apr 11, 2021
1,202
982
NB, Canada
I just got a set of Landpride PF1242 pallet forks (I think that's the part #) for my BX2380 and just shuffled a few things around here and there.....so basically almost no experience with them yet.
My completely unscientific and anecdotal impression is that they are somewhat "lighter" than my bucket and I can lift stuff quicker, easier, more accurately.
Definitely worth the $1k I paid.
EDIT: I am pretty sure you've confused the lifting capacity of them WAY low @ 250lbs.
I bet I could lift 2 or 3 times that amount.
B737
LX3310
Jun 9, 2019
2,024
2,200
Forks from Earth & Turf attachments weigh about 120 pounds.
rc51stierhoff
3,039
Forks are more useful than the bucket IMO.
I do same thing with plywood.
ajschnitzelbank
Aug 24, 2021
215
454
Rensselaer County NY
I wouldn’t typically make a blanket “you should get suchandsuch” statement without knowing a lot of details about someone’s needs. However, I agree with the general sentiment around here that forks are so handy every tractor owner (with a FEL) should have them.
I used them all the time on my b series. Palletized more things than I could have ever dreamt of before having them, carried long things like lumber/plywood/etc, mover brush, put appliances over the few steps and right through my front door, popped out small trees from the roots, used straps to lift things from above, loaded stuff in the back of pickups…
torch
Jun 10, 2016
2,617
864
Muskoka, Ont.
Made my own lightweight SSQA forks out of rectangular tube. 42" long tines. Manually adjustable width. Lifting capacity <1,000 lbs. Use them all the time.
I can't lift a full pallet of bricks or concrete sacks, but I can transfer some to spare pallets and carry the load in 3 or 4 trips.
The only problem is popularity. My son wants me to bring them over today to relocate his generator. <lol>
Reactions: 11 users
4,887
NICE !!!! love all the pictures,especially the sled transporter !
GREAT design for the forks, simple and strong.
ve9aa
Apr 11, 2021
1,202
982
NB, Canada
Great pix ! I have to move my mower deck later and am debating bucket(with hooks) or palette forks.
OrangeKrush
Nov 15, 2020
1,047
515
Indy
Sounds like an easy task for the forks!
Edit; Since you are getting use to them if sitting the deck on the forks.. maybe strap it so it doesn't slide side to side.
One thing I've noticed is the forks seem to respond differently.. depends on what and how you lift but just take it easy. Keep the RPMs lower when adjusting or lowering loads.. easy to over due it!
Mrlunchbox
2023 BX2380 loader/mower. Land Pride snow pusher, Kapteyn pallet forks
Nov 21, 2020
344
153
Southern Worcester County, MA
I have just a half acre of property and probably have used my forks more than my bucket. Worth every penny IMHO. I have a walk out basement and moving stuff from the first floor to the basement is so much easier these days. The older I get the more work smarter not harder makes sense. 🤪
ve9aa
Apr 11, 2021
1,202
982
NB, Canada
Mr. OKrush !
I'll post a pic later but yes, I used the forks. I had just the right strap to "hook' the deck.
The forks were WAY easier than the bucket, as I could see what I was doing.
Cheers
michigander
547
234
Northern Michigan
Pallet forks , not the smartest Idea I'm sure I put in the air for cleaning /changing blades. I need to find some cylinder stops for next time.
