Update: I redid the measurement with a 8' straight edge and it turns out the top of the hill I'm mowing is 56-60°. I understand the internet says I'm crazy but I'm really not having issues carefully mowing up it in reverse.
I have a40-46° 56-60° slope that I'm mowing with my BX2380 and 60" MMM. The rear are liquid ballasted and I mow with the FEL off up and down, mostly reverse cutting in 4wd at this point.
Mowing backwards up the hill is definitely 'nose down' feeling for obvious reasons but never even shows a sign of loss of traction with the R4/industrial tires on it. I get sketched out when I drive up the hill even though the front end isn't picking up at all. This is the 3rd time I've mowed my lawn with the BX and I have previously side mowed this hill on my Cub Cadet lawn mower where I could hang off the side to keep traction with R1 tires on the rear.
As such, I'm new to driving up/down hills with 4wd making the difference as there was no way I was making it in 2wd. Is there a dynamic where reversing up makes the difference with weight distribution up and down? Should I get some weights for the front? Edit: I've come to realize that the "if it's steep and you have to go up it, do it in reverse" logic is simply around having more control if you lose traction.
I have a
