I am replacing the original Kubota plastic fuel tank with a tig welded aluminum tank that only has a 1/4" NPT bottom outlet and no fitting on top for the return line. Instead of drilling the new tank and trying to place a bulkhead fitting on top, is it safe to simply put a 1/4" brass tee on the bottom outlet with the fuel supply at the bottom and the return just above the fuel line below the bottom of tank? Larger engines sometimes use the top return dump for fuel cooling and de-airing, but since the return is only 3/16" and the supply is 5/16" it seems that mixing at the bottom will still cool the fuel enough. Has anyone else done this?
