Disconnected ignition switch from harness. Measured voltage from red wire on harness side to neg battery terminal and get no voltage. Is there anything that can interupt the connection?
I really had to crank the starter for like 20 seconds before engine would start to turn over.
Do you know why the Slow Blow fuse blew?OK guys it IS the slow blow fuse that is bad. Thanks. Got an unrelated issue that I could also use help on...When mower was working I really had to crank the starter for like 20 seconds before engine would start to turn over. Bought a new starter and problem is still there. I'm thinking fuel related (dirty fuel filter?) Once warmed up, I can turn engine off and it will start back up immediately.
Usually, Dave, but sometimes.... Sometimes they just get old and tired (can anyone relate?), and they fail without there being any fault in the circuit.Do you know why the Slow Blow fuse blew?
There has to be a reason...............
