I've been hard at work over a month now on my G2160. Haven't been able to work steadily on it due to baby sitting duties at times for my little 14 mos old grand daughter but lots of work. Pulled body work, did some minor repairs to it, repainted upper/lower hood, rear fender pan. Rolled on Herculiner bed liner in place of the glued down rubber mat. Added in rear LED lights, modified OE headlight housings and installed high intensity LED array lamps, added wiring, switch and relay for using pull behind 25 gal boom sprayer (or whatever else may need electrical power). Replaced dash indicator lamps with COB LED lamps (much brighter than the old 194 incandescent lamps).
Am finally going together with it. Hopefully (unless grand baby duties crop up) it will be working hard by mid to late week
As you will see by the photos there was LOTS of cleaning to do. The PO was not very good about keeping it clean. But, finally progress is visible
