Bdubz
LX2610, 60"MMM, FEL, Grapple, Box Blade, Tiller, Moldboard Plow, 5' Snow Plow
Hi all!
Long time "lurker" first time poster...
I bought an LX2610 with 60' MMM last fall upgrading from my BX. Didn't have much time to try the mower until this Spring. Cuts great...BUT...it makes a lot of additional noise when running and lowered to cutting height. The noise is like an uneven whirring/not quite a grinding noise. If I cut tall grass and the deck is under full load, the noise stops. If I raise the deck while mowing to about half height, it stops also.
Dealer has had it twice, checked all fittings, greased everything, oil in the gearbox, etc. They DO hear the sound but can't figure it out. Their current answer is to let it wear in (mowed about 5 hours so far) and that it's under warranty.
My thought is that it is related to the pto shaft since the noise comes on as the angle of the shaft gets steeper...?
Deck is set to mow at 2.5" and I drop it to the ground as it is supposed to ride on its wheels rather than be suspended.
It works, cuts well, but the noise is driving me crazy... like nails on a chalkboard. Over $3500 for a deck that sounds like this is heartbreaking.
Thoughts?
Thanks,
Brian
Thoughts?
Thanks,
Brian
