B3030 PTO, Neutral, Seat Safety Switches
sodak
53
Sioux Falls
Yesterday I fired up my Kubota B3030 for the first round of mowing with the 72" belly mower. The engine starts to die intermittently when I'm on the seat, PTO is engaged, and HST pedal has us moving.
I'm not sure which switch is faulty - sometimes it seems to stop dying when I move around on the seat. It definitely quits dying when I either disengage the PTO and usually when I return the HST to neutral.
It appears that the prior owner jumpered whichever switch is on the right side near the linkage and rear wheel.
How do these switches work together? When working properly, I imagine some are open and some are closed circuits? Where should I begin?
Thank you;
7,194
Does it die like turning key off, or does it start to stumble/sputter?
First thought is seat switch, but if it’s stumbling, it could be a fuel flow/ starvation problem.
7,194
Yeah, just guessing, but I’d start with the seat.
I recall others having issues with newer B-series seat switches. Seems like there’s a finger-like actuator that wouldn’t quite close the circuit. Some added some padding to the mating surface make it close tighter. Not sure of the configuration of your switch, but worth looking at.
desoto bill
Kubota B3030 with loader and belly mower
Aug 29, 2020
I have a similar issue, but have no lights, no click at the solenoid, no nothing. I tried holding down the seat switch but still nothing. If it's not the seat switch, which is the next most likely switch to check? Thanks.
BAP
Dec 31, 2012
3,103
1,238
Have you checked your battery and connections? Make sure the PTO lever is in neutral.
desoto bill
Aug 29, 2020
I had just used the tractor and a portable backup jumper battery device didn't help. I have checked the PTO lever. The thing that gets me is no lights at all - dash, turn signals, headlights = nada. I'll double check, though. Thanks.
Dustball
2016 B2650HSDC
Sep 15, 2023
493
355
Hudson, WI
Lights aren't dependent on any safety switches. You have a blown fuse or an open connection somewhere.
3,349
There’s a good chance you have a main in-line fuse that is separate from the small block that holds multiple fuses. If you don’t find a blown fuse in the block, look for the main fuse inserted in a wire somewhere.
desoto bill
Aug 29, 2020
Thanks for all the suggestions. Turned out to be a negative ground wire that had corroded and separated. She runs fine now.
BAP
Dec 31, 2012
3,103
1,238
Glad to hear that it was simple. Thank You for coming back and sharing your results, it helps others in the future who have problems and search for answers in these threads.
