Top and tilt is a DA hydraulic top link and a DA hydraulic side link. At a minimum two DA cylinders requires two sets of remote outlets. You would typically have two double acting valves to go with them but its possible to use one valve and switch it back and forth betwen the outlets.How many rear remotes do you need to run a Top N Tilt? I saw something that said 1 but then saw a post somewhere (of course I couldn't find it again) where it said you needed 2.
Man I'm an idiot....I get it, so one for the top and one for the side. I'll be honest I completely forgot about the side movement which I think is why I was confused. ThanksTop and tilt is a DA hydraulic top link and a DA hydraulic side link. At a minimum two DA cylinders requires two sets of remote outlets. You would typically have two double acting valves to go with them but its possible to use one valve and switch it back and forth betwen the outlets.
Does that answer your question?
Idiots don't ask questions - they simply plunge blindly into the abyss.Man I'm an idiot....I get it, so one for the top and one for the side. I'll be honest I completely forgot about the side movement which I think is why I was confused. Thanks
Actually you need two for each operation.Man I'm an idiot....I get it, so one for the top and one for the side. I'll be honest I completely forgot about the side movement which I think is why I was confused. Thanks
Beware the ambiguous antecedent - the bane of clear communication. One valve and one set of outlets for each remote function.Actually you need two for each operation.
He didn’t ask how many “sets” of remotes… His question implied how many individual he needed… so I wanted to make that clearer.Beware the ambiguous antecedent - the bane of clear communication. One valve and one set of outlets for each remote function.
You said " you need two for each function". Two what? This is why I am advocating for careful use of pronouns and precision in terminology.He didn’t ask how many “sets” of remotes… His question implied how many individual he needed… so I wanted to make that clearer.
That's how I thought if it....just like pants...Thanks everyoneIt's like pants. You don't go and buy one pant. They call it a pair of pants - there are two legs and one waist. It is one unit, but it's still called a pair.
Same goes for remotes. One remote set includes an innie and an outie and a valve to control which way is which. It is still only one.
I would disagree.That's how I thought if it....just like pants...Thanks everyone
OK, so much for technicalities...BUT the thread title IS Top & Tilt.I would disagree.
A single acting remote has one outie which is also the innie.
A hydraulic motor remote with case drain has one outie and two innies.
A double acting remote has two bidirectional outlets.
When a tractor dealer talks remotes he is talking valves not outlets. Here is my tractor. It does not have eight remotes - it has four. One constant flow and three double acting.
My original answer to the original question was quite explicit and I tried to avoid any ambiguities about what was what. Notice I said two "sets" of outlets and two valves to go with them, I also explained that it was possible to do it using one remote valve and a selector valve just in case he had a tractor with a single remote valve already installed.OK, so much for technicalities...BUT the thread title IS Top & Tilt.
Doubt anyone would use a single acting valve on a top and tilt setup...
Exactly right. Kubota is clear on this, but what do they know? Let's defer to someone who say's EGRONOMIC when describing the layout of the controls of Kubota products.You said " you need two for each function". Two what? This is why I am advocating for careful use of pronouns and precision in terminology.
In common tractor lexicon a remote is an individual valve. That is what Kubota means when the catalog says a machine comes with one remote standard and can have a maximum of 3. E.G. the machine comes with one valve and you can add two more for a total of three. Depending on the type of valve any individual remote could require one, two, or even more outlets per valve.
How ELSE are we supposed to spend our lazy days…??…..
The conversation has since gone off the rails.
