Kubota M7500DT-A
Oktm
Kubota M7500DT
May 12, 2022
38
Utah
I just picked up my first Kubota and it's about time to get to work! It is currently functional, but the electrical has been "fixed" significantly and I want to get everything working again. Does anyone have a legible wiring diagram available? There is one I found floating around online, but the scan quality is really low and leaves a lot of guessing. Also, the previous owner pointed out that the power steering leaks... somewhere (the whole system has oil on it so I can't tell) any common points of failure on that system before I dig in?
JohnDB
M4500DT
Jun 9, 2018
396
71
NZ
... Does anyone have a legible wiring diagram available? There is one I found floating around online, but the scan quality is really low and leaves a lot of guessing.
Welcome!
PM'ing you a section of my M4500-M5500-M7500 WSM that may help. There's also a high quality scan of the M4500 wiring on kubotabooks.com, I think it's similar to the M7500.
... the power steering leaks... somewhere (the whole system has oil on it so I can't tell) any common points of failure on that system before I dig in?
Not that I know of. Best to clean it up and find where it leaks. Then use your WSM or post your query on this forum to troubleshoot or fix.
Oktm
Kubota M7500DT
May 12, 2022
38
Utah
Welcome!
I got the cap off of the power steering bottle, and that fluid looks awfully clear and thin. I am thinking the PO was using power steering fluid instead of gear oil! I am going to need to flush it out I think.
Oktm
Kubota M7500DT
May 12, 2022
38
Utah
So the operators manual calls for SAE 80/90 weight oil, and the WSM calls for ISO VG 32 and warns against mixing fluids. I am guessing the WSM would have better information, but I think ISO 32 is close to a 10 weight if my research is correct. That is a huge variance!
6,607
Simply use UDT in the steering.
