Lowering Disc Harrower
jhillsmo
B1750HST deck mower, disc harrow, post hole digger, chain harrow, powertiller
Oct 15, 2010
perry,mo
I have a new County Line compact disc harrow attached to B7510HST. I cannot get it to lower deep enough to cut dirt. Have looked at manual and see the attachment lowering limit nut and it has plenty of space. I adjusted top link so that the device is level. Don't I want all four rows of discs breaking up dirt? Still new at a lot of this. Thanx for the input.
jhillsmo
Oct 15, 2010
perry,mo
Yeah, I had seen that, am real familiar with Attachments.cm. It is not telling me why device does not go down more.
kubotasam
Apr 26, 2010
1,211
136
Alfred Maine
Remove the harrow from the tractor. Lower the 3 point arms all the way down.
Look at (or measure) how close to the ground they are. Now install the harrow. Get to a patch of ground that is fairly soft. Start harrowing with 3 point in lowest position.. Stop tractor without raising 3 point hitch. Now look at the arms and how close to the ground they are. If they are not at he same height as before you need to add weight to the harrow. If the arms are at the same height you need to raise the height of the pins that the 3 point arms connect to on the harrow.
steve l
2 m9000,9540 all cabgmd700 kuhn 605m vermeer,r23a vermeer rake,468 jd baler,
Dec 29, 2010
77
bullard,texas 75757
adjust your lift arms .i am not familiar with the compact tractors,but if it can screwed out it should be on the right side of tractor.it located on the lift arm rod.
