I used Herculiner on my Ford 1920 step and deck area 4 years ago.Well, I bought Herculiner Roll On. Kinda PO'd at the company though. All over the can are warnings not to shake, contents under pressure, etc. Instructions on the can very unclear and difficult to read. Bottom line I prepped the step, poured some of the material into a tray and begin rolling it on. Thinking this stuff looks a bit "thin". I look at the material in the can and it's nice and gloppy. So then I pour the material from the tray (didn't use much) into the can and proceed to stir it up well. Then begin rolling it on nice. Seems to be going on nice and thick. Wanted to find out dry time, look on the web site as the can is useless, and find out they recommend a "thin" first coat. Then a second thicker coat. The stuff is like roofing tar! How the heck do you get a "thin" coat?! Unless my idea of thick or thin is a different reality than that company's Anyway, it's in the garage drying now. I don't think I will try to apply another coat. Honestly looks thick enough. We shall see. Hopefully it doesn't come peeling off when I remove the masking tape
I did the hurculiner treatment on the floor of the b7510 and the pedals. I've done several truck beds with it as well. I've had outstanding results with it, but it is not as durable as many of the spray on 2 part bed liners out these days. I have raptor liner for the bed and side of my f-250. Hopefully when the weather clears up ill be able to apply it and see if it holds up. Either option if done properly is significantly cheaper then line x or rhino liner. Prep work and having the nessisary tools is most of the issue with application.I would be curious to know what the cost was to have this step coated with "Linex".
Amazon, Lowes, and others, sell a brush on product called "Herculiner" that provides the same protection.
I would venture a guess that "Herculiner", applied by a tractor owner himself, would be significantly less expensive.
I did the deck of my 1989 Ford 1920 about 8 years ago, and it still looks great.
I think the cost for the brush on can of "Herculiner" was $24.99 at the time.
If you don't mind me asking, what did they charge you for the work?Ordered a new step for my BX25d which was rusted through in a couple places. Took it right over to the Linex store and dropped it off.
1 day later…
Yes it is and well worth it!If you don't mind me asking, what did they charge you for the work?
Sorry, I found the price in one of your posts. $88 is a great price. I had the bed of my GMC pickup done when it was new. Fantastic product.
Take your time and it will all be worth it!Well yesterday I went out to the back garage and checked on the curing process of the Herculiner. Have to say it's coming along nicely as of yesterday afternoon. I am thinking by today for sure it will be ready to reinstall. Though I am holding off on that until I get a few more things done. The new HST fan, get the center stack off so I can add in the extra fuse panel and wiring I will need for the tail lights I got, electrical for the sprayer attachment and also for the conversion I am going to do for my pull behind spreader to electrical actuator rather than becoming a contortionist trying to reach back to move the flow handle. Of course full grease job as well, then finally back together, calibrate the mower deck now that I have all the new linkage for it. And it will be off to the races LOL
Well I have decided to make new holes so the new step will fit…dealer would not take the “wrong” step back.Wow - not even close. I would hope that you can get nearly all of your money back by putting it on the classifieds.
costMakes you wonder why Kubota puts a rubber mat on a steel pan, instead of just coating the whole surface, top and bottom. No rust, good traction and quiets the noise.
When I placed the old over the new it appears there will be a strip of metal between the slots…I’ll find out tomorrow when it goes “under the knife” so to speak…The one on the left is going to be double wide on the slot running front to back because it's not in the right spot anyways. You're going to have some extra large holes. But what do ya do... all that money into it!
I think plain old paint would be a better solution than that rubber, moisture holding mat.cost
Kubota could become a dealer for Linex. The cost to Kubota would probably be less than 1/3 of retail cost. Pass that tiny cost over to the customer. The cost of the Linex would probably be less than the rubber mat.cost
There ya go! Looks great!Finished product and very happy with it!
