Landpride Rotary Cutter Seal Replacement?
LarryBud
L3130
Dec 5, 2020
241
127
Cleveland, MO
I moved my rotary cutter yesterday and found a pool of gear lube puddled up underneath it. ( I had topped it off a few weeks back ). I filled it back up but must assume it wont go away.
I'm guessing the culprit is a seal on the driveshaft from the gearbox to the blades. Other ideas?
Does anyone have any experience on the replacement? While I hate to take it in, I may not have the tools to break it apart and fix it.
MOOTS
MX6000
Jun 27, 2019
1,936
2,240
Canton, Georgia
What model cutter? Here is a 12 series gearbox. Looks to be a few seals in there.
SDT
multiple and various
Apr 15, 2018
3,260
1,049
SE, IN
Most (all?) such seals can be replaced without disassembling the gearbox but you will need to remove the blade carrier, etc.
I've found it helpful to invert the mower to make access easier.
SDT
MOOTS
MX6000
Jun 27, 2019
1,936
2,240
Canton, Georgia
Had to look it up as I'm not physically on the farm. Its a RCR1260
Here’s a handy breakdown of everything.
Drop down menu let’s you look at all sections.
Looks like you can drop the stump jumper and maybe get to seal without removing gearbox. If you can get the cutter up high enough or flipped over/propped on one side. Like @SDT said a few post above.
